Tidal vs Spotify (probably again)
PNB
Morning folks-
I did a search and could to my surprise only find one thread on this... much to my surprise.
Anyway- I'm using a chromecast audio (which doesn't allow the top level master tidal stream to work).
So I'm using Tidal and Spotify back to back and I swear Tidal 320kbps is higher quality then Spotify 320kbps.
Has anyone else noticed this?
I'm objectively listening as trying to choose between the two services- I was an avid google play music fan and cant stand the YouTube music theyve move me over to-
I actually prefer the interface on spotify and listened to some stunning Jazz last night in it that I'd have never chosen myself.
But my ears are 100% telling me Tidal 320 (hifi) sounds better than Spotify.
Anyone else got any thoughts on this?
larkone
Spotify on a Chromecast is AAC 256kbps, not 320kbps. You need a Spotify Connect device to get 320kbps.
Was discussed here
PNB
Thanks- that explains the difference we can hear!
Would that be the same if we we using toslink and a DAC in the amp?
the groundsman
I believe that it is the stream from Spotify to the chromecast that is restricted, so you will still get the inferior bitrate stream turning up at your DAC. There are a few threads here recommending using the spotty plug-in on Logitech media server as an alternative as that stream is at the higher bitrate via the chromecast bridge plug-in.
To be honest I found the differences between Tidal and Spotify very marginal and on a lot of music I couldn't tell the difference at all. So while I noticed a difference between Tidal and Spotify with Tidal winning out, sometimes, it was not enough to justify the switch. I find Spotify wins on convenience, but then I have been with them for a long time and invested time in playlist creation etc.
Shame about Google Play music. I did really like the ability to upload and mix your own music with Google's stream. That's another reason I use the Logitech media Server so I can create a queue of my local music and Spotify. I found Spotify's function of loading local files was a bit messy.
PNB
Tell me about it. I've got so much personalised content for our family on play music- I'm going to have to manually recreate it all on whatever I choose between the two!
