Tidal - Best user experience but with audio quality?
Discussion in 'Music Streamers' started by stevos, Jan 8, 2017.
Tags:
  1. stevos
    stevos
    May 16, 2004
    6,179
    +580
    Using a combination of my ipad and airplay into my Marantz AVR is a great UI experience for Tidal (although wish i could use my nexus 7 as lighter than old ipad) but i can't help wondering if this is the best audio experience, since the ipad appears to be applying some amplification to the signal and clearly the Marantz does also, although i assume it is digital amplification by the ipad. I also can not find any information on whether airplay applies any lossy compression to the signal.
    I have a amazon fireTv but Tidal is not on the store.
    Using it on Kodi is a bit clunky, compared to the UI on the ipad.
    Any suggestions? Also open to cheap purchases if this is the best option.
  2. Lamboy
    Lamboy
    Dec 18, 2015
    7
    3
    telford
    easy, go grab bubble uPnP from the play store on your nexus. you can access tidal from within the app. It will also use your existing tidal playlists. I use it on my OnePlus3 to play via my Hegel H160 (which I must say is an amazing piece of kit).
