Ticking, unticking and synching in iTunes
Discussion in 'iPhone Forum' started by Shaunio, Sep 11, 2007.
Tags:
  1. Shaunio
    Shaunio
    May 4, 2006
    767
    46
    +154
    Hi all,
    Can anybody help me with what is hopefully an easy answered question about iTunes and the iPod.
    I've got a bigger music library than my iPod, so in my library I "untick" all the songs that I don't want synched across to my iPod when I connect it.
    However, when I do a shuffle play (or Party Play) in my iTunes on the computer it misses out the unticked songs.
    Is there any way to stop it doing that?
    Thanks! :smashin:
  2. kevH
    kevH
    Oct 11, 2004
    833
    Live Leeds Work Chesterfield
    +37
    Set itunes to manual synch where you drag n drop to ipod and all items in itunes will set to shuffle as they are all ticked.:smashin:
  3. Shaunio
    Shaunio
    May 4, 2006
    767
    46
    +154
    Thanks KevH - is that the only way?
  4. kevH
    kevH
    Oct 11, 2004
    833
    +37
    Think so mate as your library is bigger than your iPod capacity , just one of those things.
    You could , depending on how many times you synch your iPod, check them all and play shuffle then uncheck when you attach the iPod. Cant see any other way around it.
    Anyways manual synch is far better imho as it doesnt go thro the whole synch thing everytime you attach the iPod. Try it mate you may well like it :D
  5. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    is there an option in itunes to uncheck all the songs with one click normaly i have manualy select about 30-40 songs at a time the click uncheck and as i have over 4000 songs it takes a bit of time to uncheck them all.
  6. kevH
    kevH
    Oct 11, 2004
    833
    +37
    If your manually synching then theres no need to uncheck , cant see why you would want to uncheck everything ????? enlighten me
  7. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    its when my sister wants some music on her 2g nano, so i uncheck everthing and then check the songs she wants then sync the nano and transfer the check songs. Is there a better and easier way to do this.
  8. kevH
    kevH
    Oct 11, 2004
    833
    +37
    I have 1 itunes library and 4 iPods share this library, i manually synch all of them which means just drag and drop onto the iPod, saves all that checking unchecking rubbish.
    Just delete off the pod what you dont want and drag what you do to the iPod icon when connected simple really:smashin:
  9. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    so how do i set this up in itunes, what otion do i tick, and when i then connect this ipod does it just show up like a playlist and then i can adjust as necessary.
  10. kevH
    kevH
    Oct 11, 2004
    833
    +37
    Connect the iPod , the first screen that appears has it there "manually manage music and videos" check the box and your now driving a manual not an auto !!!:D
    You can then drag and drop music to your little hearts content !!!
  11. Shaunio
    Shaunio
    May 4, 2006
    767
    46
    +154
    Thanks KevH, much appreciated :smashin:
