Thx?
Discussion in 'Home Cinema Speakers' started by Schilly, Jan 25, 2003.
  1. Schilly
    Schilly
    Is there any real advantage to buying THX certified speakers?
  2. EvilMudge
    EvilMudge
    If you power them with a THX amp and THX processor, then yes there is some 'debatable' benefit to be had from them. Without the additional post processing, you're buying a very nice well made set of speakers that have design compromises built into them to make them perform like a THX cinema.
  3. Harold Corbet
    Harold Corbet
    I think its of benifit if all your kit is THX otherwise you wont have the right balance
  4. Mr Rumpling
    Mr Rumpling
    What exactly does THX stand for - there seems to be varying descriptions on the net :confused:.
  5. EvilMudge
    EvilMudge
    849 - Check your phone keypad.
    No seriously.
    THX:1138 was George Lucas's phone number in college.
    Oh alright, some people claim it's Tom Holman's eXperiment, pretty poor compared to the above.
  6. Schilly
    Schilly
    THX 1138 was also the name of Lucas' first feature lengthe film.
