THX Upgrade
Dfour
Why is THX so important to you??
I got an Yammy 1400 because it was THX certified and ended up almost never using any of the THX modes even with THX films. There are some awesome non-thx amps out there.
What budget are you looking at??
Dfour
Can you get a demo of the onkyo you like as the sound will be very different than your old denon. Onkyo are considered 'bright' with a lot of treble and a forth right sound.
Dfour
I'm not sure, I've never done a showroom demo before, I bought the Denon off the Internet.
In all honesty its the best thing you can do. The problem with wanting HDMI 1.4 and a THX spec amp is your stuck with Onkyo and Pioneer. Yamaha, denon and marantz only get THX on there top spec amps and they are out of your budget. Pioneer has the same 'bright'sound as the onkyo's so you really need to ask for a demo as yu will be gutted if you spend all your money on an amp and then hate the sound.
What speakers are you using?? you will need to have neutral or laid back sounding speeakers to match the onkyo otherwise you could find the sound to sharp and fatiguing to listen too.
IMHO I dont think THX is as relevant as it once used to be.
