THX Ultra 2
Discussion in 'AV Receivers & Amplifiers' started by Stewart C, Oct 6, 2001.
  1. Stewart C
    Stewart C
    Can anyone shed some light on this subject please. It has been mentioned a couple of times but I could not find the technical specifications of THX Ultra 2 on the THX website.
    What's it all about ?
    Regards
  2. bigmacx
    bigmacx
    May 15, 2001
    248
    28
    +53
    "INDIANAPOLIS— The new THX Ultra2 performance standard, devised by Lucasfilm's THX Consumer Division, includes processors that deliver 7.1-channel playback of any 5.1-channel source and, for the first time, a THX mode intended expressly for multichannel music playback.
    The spec, which replaces the Ultra spec, also changes LCR speakers' vertical directivity requirements, which some speaker engineers said made it difficult to build Ultra-certified home theater speakers that were also musical."
    The rest of it can be found
    here
    Hope this helps,
    Mac.
