Thx test screen
Discussion in 'TVs' started by jem, Jul 13, 2003.
  1. jem
    jem
    Sep 24, 2002
    527
    +7
    I've read about this test screen but can someone explain how to use it please?
    I have "Star Wars - Attack of the Clones" DVD. Where is it on this dvd please?
  2. Jase
    Jase
    Mar 16, 2001
    9,536
    UK
    +937
    You need to look for the THX Optimizer feature (small silver THX logo). I think it's under the SETUP or OPTIONS section.
  3. shawkins002
    shawkins002
    Dec 12, 2002
    236
    Epsom, Surrey
    It's under "Languages" on AOTC.
    Go in to the video tests and use skip + to work your way through the tests. I alsways thought there was just one screen until I pressed the skip button by accident........
  4. jem
    jem
    Sep 24, 2002
    527
    +7
    Found it thanks.
  5. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    Next question - How do i access the service menu on my tv to correct the geometry ? ;)
  6. jem
    jem
    Sep 24, 2002
    527
    +7
    Yes it would be but having searched the forum I couldn't find anything on the Philips 6515. I seem to be missing a bit of the picture at the bottom.
    On my other set I'm missing a bit of the picture on the left and the bottom - JVC AV28R25.
    As both are still under warranty, perhaps an engineer might be best? I've got one coming tomorrow for the Philips set.
  7. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    I wish you luck with Philips. I had a minor geometry issue that required adjustment, Philips advice was to 'take it back to the vendor' as my first point of contact.Fine, exept it was purchased from a large supermarket chain and i knew they would be unprepared for a service matter.I contacted Philips and explained the situation and if they were prepared to provided me with a means of access to the service menu then i would attempt to correct the geometry at my own risk.Philips were adament that i return the set to the supermarket.Philips got a returned set unnecessarily and i got the purchase price refunded ... altogether an unsatisfactory deal for all concerned.
  8. jem
    jem
    Sep 24, 2002
    527
    +7
    It was bought from QED. They've put me in touch with a company who are sending an engineer out tomorrow. We'll see what happens.
