THX Speakers
Discussion in 'Home Cinema Speakers' started by ArcticFox77, Aug 25, 2005.
  1. ArcticFox77
    ArcticFox77
    Aug 8, 2005
    82
    Scotland
    Is it really important to have THX speakers if u have a THX certified amp??
  2. recruit
    recruit
    No not at all, any speakers of good quality will work fine with a THX certified amp. :thumbsup:
  3. ArcticFox77
    ArcticFox77
    Aug 8, 2005
    82
    Scotland
    That's good to hear, thanks.
    Another little thing how much is THX speakers coming in at/?
  4. recruit
    recruit
    There are quite a few speaker makes that are THX certified and alot of them are mostly studio type monitors with THX pm3 certification, Bluesky speakers go for approx £365 each another make is Mackie which i am not too sure about on price, i have M&K S-150's which are about £800 each and these are THX Ultra certified.. :)
  5. narcoticsuite
    narcoticsuite
    Jul 7, 2005
    91
    THX is really of dubious benefit as far as hardware is concerned. I wouldn't even bother specifically looking for it if I were you. Alot of THX certified kit is no better or worse than non THX certified kit. and it could be argued that THX certification simply adds to the production costs and so THX kit is inherently overpriced.
    Effectively, what happens is that the manufacturers pay George Lucas so that they can stick little badges on their kit.
  6. S H A D O
    S H A D O
    Mar 16, 2001
    10,290
    United Kingdom
    +1,570
  7. recruit
    recruit
    Some good links there Jase :thumbsup:
  8. MannyMore
    MannyMore
    Dec 20, 2005
    77
    Ipswich/Bury st Edmunds
    THX certified equipment is certainly a "thorn in side" when considering buying, it is however, a very specialised technology, I have read many articles concerning how it works and unless you have a decent size & shaped room I can't see a lot of benefit for, most people. It's an expensive "extra" but, not an essential and I won't be investing in it in the near future.
    Thanks for the links Jase...:)
