THX Select logo: marketing or mark of quality?
Bonce
Sorry if this is a naiive question but Is an amp with a THX Select logo a sign of quality, or should I completely ignore it and consider the other qualities of an amp when deciding what to go for?
buns
it is a sign of an old amp..... this standard has now been superceeded by my understanding
ad
Bonce
Eh? Surely not. There are two brand new amps (Yamaha and Onkyo) carrying the mark reviewed in the March 2004 issue of Home Cinema Choice...
fred123go
hardly the sign of an old amp ad, quite a few new receivers have the select status, such as the pioneer 2011 and some yamaha and onkyo ones.
THX select/ultra certification can be rather misleading, go to www.thx.com to find out more about how it is 'awarded'. But generally shows that a receiver is capable of playing loud, THX select in an area under and has thx processing to tame down treble a lil bit.
You should certainly not just look for a receiver/amp with THX select status, there are loads of amps that have not applied for the specification that are potentially better than amp's with the logo.
Many might just say it is a nice logo to have on your equipment, me being one of them ;), but you should really look at the overall performance of an amplifier before deciding. I for one find the re-equalisation feature that THX has to be the main advantage.
fred
buns
ok..... apologies....... i thought select had gone. Does ultra still exist? If so, where does it stand wrt ultraII?
I think i basically answered IMO though :D from what i said you probably guess that i wouldnt be paying too much attention. I may be a bit more swayed by an ultra2 spec though
ad
fred123go
yeah thx ultra has been overtaken so to say by thx ultra2. I dunno too much about it but i think ultra2 is more musically balanced.
thx ultra2 would probs alsp sway the spec as it is probably going to be superior to other no spec'd ones
fred
avanzato
There's an interview with a THX bod on Audioholics that covers most of what they do. Basically the minimum specs are: Select is 5.1 for smaller domestic rooms, Ultra is the original 5.1 THX and Ultra2 is 7.1 for big rooms with music mode.
IMO the THX badge shows the amp has passed a set of tests setting a certain level of performance. It doesn't mean the amp will always be reliable or easy to use or even sound fantastic. As fred says you do also get the THX tweaks to improve the sound from movies if you like the idea of that.
BiggieBig
IMO opnion the thx logo is nice to have, but a little pointless if all your wirings,conectors,players and even room doesn't pass thx tests...
I wouldn't bother with this too much. Best way to find a good amp is search the forum and go and demo...
Smurfin
Nonsense. Just because my speaker cable and interconnects aren't THX certified renders THX processing pointless?
:rolleyes:
Dimmy
:rolleyes:
Potentially yes :D. Your cables, interconnects, DVD player etc etc could all be exerting character on the sound which gives the opposite effect to what the THX-Post Processing is supposed to do in the first place.
It's unlikely, but entirely plausable.
Smurfin
Oh please:rolleyes:
Dimmy
Oh please:rolleyes:
Oh don't get too technical... :p :D
avanzato
I think it was a mistake THX deciding to do cables in their certification programme. I can think of several reasons why THX would certify cables none of which involve sound quality and all of which involve $$$
They didn't used to do cables and the systems sounded all right in those days.
A quote from the interview I linked to:
"Another way to say this is, that if something seems wrong, it's probably not the THX Certified component. This is a key and often overlooked point because, with modern high quality gear used within its designed limits, the room itself, the equipment setup and the calibration have much more influence on the sound than the inherent character of the equipment. This is not to say that the gear doesn't matter at all, it does, but a mediocre room or system setup will invalidate judgments about the gear by masking those differences."
See the room is more important than any difference between cables or even amps. AFAIK THX have tight specs for the cinema auditoriums but not for domestic installs. There are recommended layouts but you can modify them to suit your own requirements.
Daneel
THX certification is the sign of a more expensive amp, because you have to pay for it. More expense is not what I want so I'd be happy to see it gone. Having said that it does given an idea of performance, but then if you do any research before you buy you could tell that for yourself. It's interesting to see those items not THX certified, some are very high end so you wouldn't even question the quality and others are either low end or with questionable reputations (Bose).
My receiver is THX certified, I'd prefer it not to be, I might have got it £20 cheaper!
BiggieBig
Daneel
I agree with you completely.
Though you probably payed alot more then £20 for the certification, but then I suppose the amp will probably hold it's value better if most consumers do value the thx certification highly....
May well be worth the extra cost if your amp runs into many 100s
Bose would be incapable of getting any kind of certification.....
Daneel
What makes you think I payed a lot more than £20 of my amp cost towards THX certification? It isn't THAT expensive is it? Remember the cost is amortised over x thousand units sold.
BiggieBig
That's probably what they pay Lucos for certification
how much does the manufacturer add on top just cos it’s certified and more marketable
fred123go
Going back to whoever made the point about THX being pointless without an all thx certified equipment that is a ridiculous point to make. It hardly makes it pointless to have. THX processing makes a very big difference to those 'bright' soundtracks at higher volumes on both my present(use of logic 7) and old system and just because i for one am not willing, or should i say to skint to, spend a few hundred quid on THX speaker cable(never actually come across any)/or an extra grand or so on a THX dvd player(which i believe has only to do with the visual part of a system and no improvements over the sound part-correct me if i am wrong).
But i do agree to get the best out of THX processing or your system as a whole you have to spend careful time to calibrate and test different things, perhaps spend a bit more on reasonable speaker cable and probably something i will invest in in the summer some kind of sound absorption material to help tame treble reflections. None of the above though has to be THX certified....
fred
avanzato
What you pay for with THX is the many years of research into how to make movies sound consistantly good. I don't know why people have such a downer on this. It's not like you can only buy THX receivers, they're way outnumbered by the ones that don't carry the badge. Exercise your choice.
and Bose well Bose have the money and R&D to build whatever they want and to whatever Spec or Certification. What they choose to build is speakers/radios etc. that sell at nice profits to the public. Bose are too easy to slag off because they are so successful.
Ian J
My sound quality has improved enormously since I installed a THX approved shag pile carpet :D
Daneel
That isn't why Bose are slagged off.
B
bobbypunk
surely it does make a difference to use some rather than all THX components. The principle is every time you change to the next THX component you are one step closer. Most THX Items are to do with acting like a scaled down cinema where as most AV systems won't necescerily follow the same rules.
fred123go
I think most av systems would act like a scaled down cinema, they are aimed at pretty much a mass market and the fact that they are 'home cinemas' really means a scaled down cinema. A lot of av components would pass the THX certification with flying colours but wish not to.
I have a THX processor, THX amplifier, and THX speakers but i reckon that many other speakers would outperform them and don't have the THX logo. Although i am perfectly happy with my sound system as it truly does sound better than a cinema, well my local crappy odeon one anyway. The point is my system would sound better with say the B&W Nautillus range e.t.c
I am not prepared to pay >1000 for a dvd player just because it is THX, as it would not offer any advantage sound wise to any other mid range dvd player. This also applies to speaker cable/interconnects or whatever
fred
Paramount + UK launch: Halo, Star Trek and Beavis, and all the latest 4K + Movie/TV News
Latest News
Huawei unveils FreeBuds Pro 2 true wireless earbuds
  • By Ian Collen
  • Published
Sony unveils Inzone gaming brand
  • By Ian Collen
  • Published
Bowers & Wilkins launches Px7 S2 wireless headphones
  • By Ian Collen
  • Published
AVForums Podcast: 27th June 2022
  • By Phil Hinton
  • Published
Movies Podcast: 27th June 2022
  • By Casimir Harlow
  • Published
