THX or DTS/5.1
Discussion in 'AV Receivers & Amplifiers' started by oreoboy13, Mar 28, 2002.
  1. oreoboy13
    oreoboy13
    You can see what stuff i have below, so i ask;
    Do fellow AVC-11SR use the THX post processing option all the time?
  2. rnjones
    rnjones
    oreoboy, I have tried THX on a variety of sources. Of course DD 5.1 THX labeled stuff.
    Before I set up my system again with the SPL meter I was using THX on Sky Digital if the material was older, like an old Inspector Morse as this seemed to make the dialogue clearer.
    Since I have tweaked it with the SPL meter I dont seem to need it any more.
    The other problem is that my bird gets grumpy if I switch it on and off whilst watching.
    I do need to do some more listening tests. No time currently.
    Rog
