THX Optimode
Discussion in 'Movie Forum' started by calibos, Feb 12, 2001.
  1. calibos
    calibos
    Aug 4, 2000
    930
    Ireland
    +33
    Does anyone know of any Region 2 discs with the THX Optimode on them? I want to use it to tweak the settings on my tv and reciever. It was on the Region 1 Fight Club and Toy Story Box Set and when the reviews of the R2 versions said all the extra's were intact, I assumed this meant the Optimode too.
    Don't be a don't be.......Be a do be!
  2. Hendrik
    Hendrik
  3. Pollywoggle
    Pollywoggle
    Aug 14, 2000
    1,442
    South Shropshire
    +80
    I'm probably missing something but I don't see where it mentions Region 2?
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,133
    +1,179
    Hmm I could do with decent 625/50 colour bars myself.
  5. Hendrik
    Hendrik
    ...American test discs for DVD are aimed at North Americans (geographically, this includes Yanks, Canucks, and, yes, even Canadiens) who, for better or worse, are stuck with their NTSC system - as are the Japanese (also Region 2) and Hong Kong (Region 3, or Region 0)...
    Perhaps someone knows of a European - i.e. specifically-made-for-PAL - test DVD ? I certainly don't.
    ! [​IMG] !
  6. Mr.D
    Mr.D
    Jul 14, 2000
    11,133
    +1,179
    Well the NTSC/PAL colour issues are moot with dvd as its a component format. Generating a PAL or NTSC colour signal is a function of the player. So if you generate a PAL60 signal from a 525/60 disc its valid.
    The only issue is how your TV stores settings for a calibration point of view. Having a 625/50 formatted colour bar would be useful purely to cover all eventualities. In practice a PAL colour bar generated from 525/60 is accurate its just a question of how your TV applies its settings to the 525/60.
    If you are using component or RGB its not an issue.
    There are some complications involved with using a composite signal because an NTSC composite signal utilised a relationship between the line rate and the colour frequency but in practice again this problem is slight to non-existant. (and who would want to use composite from dvd anyway)
  7. charles
    charles
    Jul 6, 2001
    1,338
    63
    norwich
    +166
    I would say this re;-ntsc.
    The thx optimode tests are optimised for ntsc-this is fairly meaningless if you are calibrating watching a pal disc-there are differences in calibating a pal or ntsc signal.
    For a start,the hue setting on your projector/t.v.during calibration whilst playing an ntsc disc can greatly affect the colour bars-and if you set the colour bars-then jump to a pal disc and start the same calibration,you will notice the colours look slightly washed out.
    What i have done,is calibrate on one memory bank for ntsc,and one memory bank for pal-my settings are quite different.
  8. Mr.D
    Mr.D
    Jul 14, 2000
    11,133
    +1,179
    No their not. They normally originate as 4:2:2 yuv downsampled via MPEG2 to 4:1:1 (or 4:2:0 it varies) its still a larger chromaticity range than can be represented by either a PAL or NTSC colour signal.
    The easiest way is to avoid using NTSC at all if possible. Use RGB or component ideally or PAL60 via s-video if you must. Using NTSC just unecessarily limits the colour bandwidth you are pulling off the disc and it introduces other calibration issues: RGB , YUV and PAL have similar set-up criteria. NTSC is different (higher black point : but it all clips in video anyway however your player may or may not apply the higher 7.5IRE set-up level again a source of possible confusion).
    How your TV stores settings for a 525/60 signal compared to 625/50 signal is another matter but its seperate from the PAL/NTSC one (which is effectively meaningless with dvd)
    Read the Joe Kane interview a couple of months back: he touches on this but not in any great detail.
  9. charles
    charles
    Jul 6, 2001
    1,338
    63
    norwich
    +166
    Mr d,
    I`m sorry old chum-but your wrong,you forget that the thx optimode on an ntsc disc has been pulled from an ntsc master..
    Via s video using pure ntsc and calibrating will elicit one set of optimum settings(hue especially-and differnt again if you use the ntsc matrix on my ellie projector..)..whereas putting on a pal disc requires re-optimisation.(colour temp with regard to reds seems cooler for pal discs)
    Hence i have different settings for ntsc dvd`s and pal dvd`d-which is recommended..
    Joe kane never said that pal and ntsc could be calibrated in one go using the optimode-he said that once ntsc calibrated-pal discs would benefit.
