THX Optimizer with region 1 or 2 Incredibles dvd?
Discussion in 'Blu-ray & DVD Players & Recorders' started by TankTopLover, Sep 21, 2005.
  1. TankTopLover
    TankTopLover
    Aug 28, 2005
    4,144
    +189
    Is it the region 1 or 2 dvd or is it both? I want to get the incredibles and would also like the THX optimizer i have heard people mentioning,a direct link to a site that sells it would be great :lease:
  2. Timbo21
    Timbo21
    Dec 23, 2004
    4,632
    3
    London
    +315
    I know it's definitely on the R2 version. :)
  3. TankTopLover
    TankTopLover
    Aug 28, 2005
    4,144
    +189
    Thanks.
    Also is there any difference in pq between region 1 and region 2 dvd?
    Its just i notice alot of people have region 1 dvds in their collections??
    I have bought the region 2.
  4. Timbo21
    Timbo21
    Dec 23, 2004
    4,632
    3
    London
    +315
    I don't really know much about this. But, region 1's are NTSC, which mean it has
    480 lines of horizontal resolution, whereas region 2, which are PAL have 576.
    So, theoretically region 2 should be better, because of the better resolution.
    However, maybe more importantly is the care & skill taken over transfer, and perhaps in the US they are doing a better job? I don't know, but I would be interested to know if the US transfers are generally better.
    Can anyone else with more knowledge comment on this?
    T. :)
  5. Ross82
    Ross82
    May 3, 2005
    202
    +12
    Ive got the R1 disc and the THX optimiser is also on there.
    :thumbsup:
  6. TankTopLover
    TankTopLover
    Aug 28, 2005
    4,144
    +189
    Well a huge amount of dvds reviewd on this site are region 1 or 3?
    It seems there must be a reason for this?
  7. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +795
    Released quicker, that is the main reason, see your other post asking the same thing.
    I don't like judder on pans, and US material will give it when pal material will not on film based material anyway.
    With region 1 stuff you need to get 60 frames a second from the original 24 of the film, do the maths and see it is not easy, with pal they just speed it up a touch to get 25 frames a second, and then show each twice, far easier, but as someone else pointed out, in your other thread, if you have perfect pitch you may find this very annoying.
    You also tend to find US discs have more edge enhancement which I hate too, not sure why, maybe becuase there is 20% more vertical resolution on Pal they don't feel the need to try and sharpen the image up? (which is a good thing).
