thx optimizer 200hz-2-hz sub test tone what use is this
Discussion in 'Subwoofers' started by mick23, Jul 1, 2002.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    r2 star wars phantom menace has thx optimizer part of (test) runs a 200hz-20hz through front speakers and sub, cannot see how this helps to configure speakers or sub, any advice plese on how to use or adjust thank you
  2. Jase
    Jase
    Mar 16, 2001
    10,815
    United Kingdom
    +2,693
    Its to see if you have a drop off in bass around your chosen cutoff frequency. If you have the cutoff set too low you´ll get a "gap" in the bass between your main speakers and when the sub takes over. Its also handy to see (hear!) how far low your systems bass extends.
    For proper calibration use either AVIA or Video Essentials test discs.
    AVIA available here:
    www.ovationsw.com
    Video Essentials here:
    www.ezydvd.com.au
    cheers
