thx kef thx
Discussion in 'Home Cinema Speakers' started by grahamricho, Jan 10, 2002.
  1. grahamricho
    grahamricho
    Oct 29, 2001
    697
    York
    +12
    why does my denon avca1d which is thx certified,and my kef thx certified speakers,while playing the pod racing from star wars thx .my certified thx sub nearly falls apart,even when listening well below reference levels,on bridget jones diary the same thing happened,duing a music section the bass was too much.i,ve double checked all conections and levels.surly thx discs should play on thx gear spot on?????
  2. dts_boy
    dts_boy
    Nov 26, 2001
    2,615
    Manchester suburbs...
    +178
    it sounds like its been switched from thx to normal/variable. check that, if not i'me not sure it may well be the amp. i got the newer a1se and that had bass problems. it has since been replaced and had no issues since then.
