Thx do i need it
Discussion in 'AV Receivers & Amplifiers' started by tracer, Jul 6, 2002.
  1. tracer
    tracer
    Newbe question.
    The THX sound format should I buy an amp with this sound system if so why? and does it add mega bucks to the overall cost.
  2. Ixon
    Ixon
    Jul 3, 2002
    182
    Wigan, England
    +4
    Just stick with DD & DTS
  3. docsmith2k1
    docsmith2k1
    Apr 20, 2002
    520
    Liverpool
    +17
    THX is not a sound format, more a set of guidelines that define how home cinema equipment (everything from speakers and amps, to interconnects and speaker wire) should perform to provide optimum sound and video reproduction. It is licensed by Lucas, and manufacturers pay in order to have their equipment THX certified, to confirm that it conforms to these high standards. THX certification is not cheap - neither is producing equipment that conforms to their vey high standards. Consequently THX certified equipment does tend to be at the higher end of the price scale, but it is a guarentee of quality, although non THX equpment can sometimes surpass THX standards, but to save money the manufacturer doesn't pay the premium to have it THX certified.(yamaha for example)
    AndyS
  4. Marv
    Marv
    Jun 7, 2002
    3,212
    Kekistan
    +1,433
    THX does not always = better.
  5. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Please explain
  6. docsmith2k1
    docsmith2k1
    Apr 20, 2002
    520
    Liverpool
    +17
    Marv if your refering to my post, read again - at no point do I mention THX being better. However what THX attempts to do is bring objectivity into an area normally totally subjective - ie you and I would both hear the same thing although we might disagree about which sounds "better".
    This too could be corrected if our hearing could be THX certified. Lucas could be working on this as we speak. We could all pay a fortune to have THX approved tattooed on our earlobes (I'd go for THX Ultra2 myself):D
    AndyS
  7. stranger
    stranger
    THX will bend it's own rules (guidelines, specs whatever) at the drop of a £ sign.
  8. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Having a THX amp myself I do know a little about the subject but was merely querying a six word statement by a newbie that "THX does not always = better" on the basis that the statement is not worth the bandwidth unless an accompanying explanation is offered.
    For all we know Marv may have only been into home cinema for a week and is passing on nuggets of information supplied to him by the Saturday boy at Currys.
  9. stranger
    stranger
    ian, i posted the wrong quote-sorry:)
  10. Marv
    Marv
    Jun 7, 2002
    3,212
    Kekistan
    +1,433
    Yeah, i went into a home cinema shop to look at the stuff.Did'nt even consider buying anything after seeing the prices in the shop.The bloke in the shop was going on about how THX standered equipment was not always the best.
  11. Guest
    thx means its better made and has good special effects sometimes.
  12. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Having just put two products through THX for approval I can tell you they are very rigorous and quite picky about what they want.
    Electronics products that are THX approved will have been designed to a pretty tight spec in both audio and video terms - the latter are particularly onerous and you can't cut corners.
    Whereas there may be big differences between loudspeakers designed to meet THX's original spec and those designed for high performance in a home music system, there is no reason to suppose that a modern THX Ultra 2 electronics product used within its performance ratings will sound worse than a non approved product - generally it should be better.
    Just my opinion of course, though based on real experience!
    John Dawson (Arcam)
  13. docsmith2k1
    docsmith2k1
    Apr 20, 2002
    520
    Liverpool
    +17
    FYI THX has been sold to Creative Labs
    Start of a thread in the other forum.
    What do members think?
    As was stated in this thread - a significant reason for paying the extra these products cost is the knowledge that some of the best sound and vision engineers on the planet are behind its implementation. Do we feel this way about Creative?
    AndyS
  14. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,632
    UK.
    +3,132
  15. Jase
    Jase
    Mar 16, 2001
    10,803
    United Kingdom
    +2,693
    THX certified means the equipment will reach a minimum excellence. There are two types - THX Select and THX Ultra (now Ultra 2). Ultra & Ultra 2 are higher end, Select is lower priced.
    THX amps have THX post processing which is designed to replicate the sound of a cinema in the home. For info have a look here www.thx.com
    THX Ultra 2 post processing now has both Movie & Music modes and is designed for a 7.1 system. THX post processing can be added to Pro-Logic, Pro-Logic 2, DTS 5.1, DTS 6.1 Discrete & Matrix, Dolby 5.1, 5.1 EX etc etc depending on amp.
    Check out the THX website for more info on the various THX requirements for speakers, amps etc
  16. Harold Corbet
    Harold Corbet
    I thought the sound effects they gave you was no good. Stuff like hall, concert and all this will surely make it sound worse.
  17. docsmith2k1
    docsmith2k1
    Apr 20, 2002
    520
    Liverpool
    +17
    Hall, stadium etc are a TOTALLY different kettle of fish all together. These are DSPs (digital sound profiles) - they are produced by certain amps to "recreate" the acoustics of a particular environment. They are certainly not related to THX in any way shape or form.
