THX Blue Optimiser Glasses?
Discussion in 'Plasma TVs' started by image165, Jun 28, 2005.
  1. image165
    Sep 30, 2004
    145
    +3
    I don't know if I'm posting this in the right forum. Probably not. But I was just wondering, do most of you have those Blue THX Optimiser Glasses, for optimising your Plasma screens? If so, where did you buy them from? Can you buy them from a physical shop? If so, which one(s)?
  2. neilios
    neilios
    Dec 18, 2004
    6,868
    halifax
    +2,389
    I spent ages looking for some blue and red filter glasses for my hitachi but then i realised in the colour decoding options it has rgb and then red ,blue,and green options ,light one of the options eg blue and it places a blue filter over the picture .
    Then i adjusted the setting that way .
  3. JeffLaws1
    JeffLaws1
    If you get hold of one of the optimising DVDs such as Digital Video Essentials they supply a set of red blue & green filters, DVD only gosts £20 approx and does to some small degree help.
  4. image165
    Sep 30, 2004
    145
    +3
    Oh right. Thanks for telling me about Digital Video Essentials. So, the ASIN: B00009WW03? Just checking I've got the right one.
    Is that the best Plasma/LCD optimising DVD available then? Or are there alternatives? And are the red/green/blue filters packaged inside the DVD case?
  5. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    You can get it cheap on a PowerBuy, if you're quick, I think....
  6. image165
    Sep 30, 2004
    145
    +3
    Amazon.co.uk sell it for £19.99. Is that what you call cheap?
  7. JeffLaws1
    JeffLaws1
    If your british you need to make sure its the PAL version and yes the filters are inside the DVD case, is it the best? no, professional ISF calibration is supposedly the best but it will give you better results than the basic out of the box settings on any TV, plasma, crt, lcd
