THX and DOLBY demos
Discussion in 'Movie Forum' started by Salem Doom, Aug 15, 2002.
  1. Love Em
    23 vote(s)
    95.8%
  2. Hate Em
    0 vote(s)
    0.0%
  3. Never Heard Of Em
    1 vote(s)
    4.2%
  1. Salem Doom
    Salem Doom
    Okay Can anyone please tell me a site where I can download the excellent trailers for thx / dolby digital /dts?
    I may be a bit sad, but I love thesse trailers and they are good demos for testing out your kit :)
    :eek:
  2. docsmith2k1
    docsmith2k1
    Apr 20, 2002
    520
    Liverpool
    +17
    Never seen them as downloadable files - you can however purchase a dolby digital demo disc from dolbys website, with all the trailers your familiar with and one or two you probably havn't seen before.
  3. Salem Doom
    Salem Doom
    I allready have the Dolby disc, I found some MP3 downloads of audio files to test yout set up on the MP3 download site Kazaa, the adress is as follows...
    http://www.kazaa.com/en/download.htm http://www.kazaa.com/en/download.htm
    I have found some sites that ''used'' to have them as either AVI files, VOB files, or MPEG files, but every site I have visted has broken links :(
    :mad:
  4. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    Essex, unfortunately
    +3
    Have a look here under trailers.
  5. Salem Doom
    Salem Doom
    This is one of the sites with broken links, the VOB files work okay, but what is the point of ONLY being able to view them whilst online?
    I want to be able to save them, burn them to VCD, then be able to tinker with my Dolby Digital setings with them, at the moment this site ''cineworld'' will only let you get the VOBS, again the MPegs and Avis dont seem to want to work
    (I have tried geting in via netscape and Ie :()
  6. Xeonic
    Xeonic
    What's wrong with the VOBs? You can download them, and play them in a software (hardware) DVD player, isn't that the point? Without VOBs, you're looking for a 5.1 mpg, or avi which although does exist, isn't that compatible. In 2 channel mpg or avi format, there's obviously no 5.1, so that isn't much good either...
  7. Salem Doom
    Salem Doom
    Okay lets say I did download the VOB files, how does one save it to disc (VCD) I am using nero :) Thanks in Advance
  8. msmorley
    msmorley
    Apr 24, 2002
    35
    Exeter, UK.
    I don't believe this can be done - I've tried using Nero to master these trailers (I've got 12 or so of them as .vobs) onto a DVD (ok, it's a CD-R really). Apparently, the problem lies in the data transfer rate from the CD being insufficient for the video and the DD soundtrack. Pity really... I'm not buying a DVD writer just for this - unless anyone knows anything different...?
    Cheers,
    m.;)
