thumbnails? Re using and resizing
Discussion in 'Blu-ray & DVD Players & Recorders' started by dvdud, Nov 11, 2004.
  1. dvdud
    dvdud
    Hi. Don't know if this is a relevant topic but here goes anyway
    Can anyone tell me if its easy to transfer/resize the thumbnails I (haven't got or seen a dvd recorder in action but believe thumbnails are presented on tv via the dvd recorder if i read correctly elsewhere), as I wish to use some of my vhs recorded still images on a web page, once i've transferred them to dvd. Hope this makes sense! If not, i completely understand - as i'm confused re-reading the above!
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,775
    Warwick
    +2,675
    The easiest way to do this is with a PC DVD player such as WinDVD ( www.intervideo.com ) which allows you to capture screenshots from the actual programme - don't try and capture menu thumbnails! You can then resize your captured pics in virtually any graphics package.
