throw ???
Discussion in 'Projectors, Screens & Video Processors' started by pinky3003, Mar 31, 2005.
  1. pinky3003
    pinky3003
    Jul 24, 2003
    221
    hi chaps, everything is in place for projector to be installed.......thats the easy bit.
    im looking for a 2m pic from 6m projector position.....i take it i will need a long throw lens ???
    budget is around 1k-2k.......your help is most appreciated.
    pinky
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    You'll need a very long throw lens for that application, I'm not sure I've ever seen one that long, certainly in the price-range you're looking at.
    If you look through a list of projectors you can use ProjectorCentral's throw distance calculator to see what it's limits are.
  3. sjb
    sjb
    Jul 1, 2004
    114
    S.E. Scotland
    You'll need a throw ratio of 3 : 1 then, the Sim2 Domino 18 and Domino 20H would be suitable.
    Best Regards,
    Stan.
  4. cyberheater
    cyberheater
    Apr 3, 2003
    3,225
    Scotland
    +179
    Can someone explain how the throw calculation works.
    I think i've got it but would like to make sure.
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Not sure what you're asking. :)
    Are you asking what 3:1 means, how throw distance is determined, or something else?
  6. sjb
    sjb
    Jul 1, 2004
    114
    S.E. Scotland
    Cyberheater,
    Throw ratio = Distance between screen and projector lens : screen width.
    In this case it's 6 : 2 which is the same as 3 : 1.
    Best Regards,
    Stan.
  7. obvious
    obvious
    Jul 17, 2002
    82
    +4
    Out of interest, are you supposed to measure from centre of screen to centre of lens?
  8. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Generally yes, but remember that most (all?) projectors provide some amount of 'zoom' so you have some leeway how far back or forward you can locate the projector.
  9. cyberheater
    cyberheater
    Apr 3, 2003
    3,225
    Scotland
    +179
    Thanks guys. That explains it :smashin:
  10. pinky3003
    pinky3003
    Jul 24, 2003
    221
    thanks for the advise chapps (stan) ....seems the sim2 20H is the one to look at...after a google i see i can get it for just short of 3k......im going to get a demo over next week or so.....in the mean time-keep saving......time to look for sim2 20h threads....cheers pinky
  11. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I thought the budget was 1k-2k. :D
  12. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    pinky3003,
    consider the Domino 18 also as it is £700 less than the 20H at £2299.
    Jeff :rtfm:
  13. pinky3003
    pinky3003
    Jul 24, 2003
    221
    Kragorn.....seems i got tp up the budget (since when has that been a shock regarding AV).....rtfm...i need a dvi input....i have HTPC with theatre tek and ffdshow.....I do have another statement to make but i will start a new thread.....its with regards to when can i say stop "Im happy with what i got"....???
