throw distance
Discussion in 'Projectors, Screens & Video Processors' started by Jack the lad, Jan 28, 2003.
  1. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    New Zealand was Nottingham
    +86
    Hi, I would be grateful for some advice about throw distance. I am having a barn converted and have a room which is approx. 14 ftx11 ft which I intend to be used for watching movies in. I plan on buying a projector and mounting it in the middle of the 14" wall at a height of about 8 ft. What kind of 16x9 image size would I be able too achieve?
    Thanks for any help
    forum Virgin!
    Jack
    Current system
    Sony 1080 6.1 amp, Sony NS 900V DVD, AE Evo3 front speakers, Mission M7 Di pole surrounds
  2. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    Depends what projector you go for.
    I would think you would need a short throw lens.
    I have a similar setup and at 13' achieve an 8ft wide image.
    This is about right, anything bigger in the room would be a tad uncomfortable.
    There is a website that has a projection throw distance calculator on it but I can't recall which one.
    Do a search on this forum.
    Best of luck.
    Chris
  3. stubie_do
    stubie_do
    Sep 8, 2002
    243
    Suffolk
    +33
  4. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    +86
    Cheers for the help guy`s.
    The link worked out great Stuart.
    From a Panasonic AE100 at:
    10ft image size 6.9-8.5ft
    11ft 7.6-9.4ft
    12ft 9 -11.1ft
    Any of the above will be better than the 40" from my Tosh rear projector!
    Thanks again
    Jack Daws
  5. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    Try to avoid zooming on th epanny.
    Use the least zoom to obtain the best image, so use the first figure in the calculation.
    If possible use a HCPC - I know its added fiddling but worth it when you see the picture...awsome :)
  6. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    +86
    Hi Chris,
    What a HCPC?
    Im new to this stuff.
    Jack
  7. Markatlarks
    Markatlarks
    Jan 8, 2003
    123
    Truro, Cornwall
    A PC which has specially selected components which meet the high demands of the projector. (IE Home Theatre Personal Computer)
    I guess you could use any PC but typically (based on the various threads in here) one which has VERY quiet fans, maybe even liquid cooling. A case that does not emit light (dont want lights in your cinema!), a super fast graphics card - agp with 128mb (Radeon 9700 etc) and maybe even a hard drive caddy where the HDD is suspended on rubber bands. An also a quiet DVD drive.
    Some cases have all the connections on the front and are much easier to 'use'. The Shuttle PC goes someway to addressing this.
    Good Luck
