Throw distance for a seleco svd 800 hd millenium.
Discussion in 'Projectors, Screens & Video Processors' started by brian aitken, Mar 27, 2006.
  1. brian aitken
    brian aitken
    Could anyone tell me the throw distance from the centre of the green tube to the centre of a 80 inch 16/9 screen for the svd 800 hd millenium with brand new tubes.Also is the AKB line visible at the top of the screen in 16/9 mode just like the svp 400 plus.
    Thanks Brian
  2. Anders B
    Anders B
    Jan 11, 2005
    48
    +4
    The throw distance is 1.5-1.6 (distance/screen width) depending of the installation type. You can download the entire operational manual from www.curtpalme.com. The AKB line is not visible with this projector...I have spent 1300 tube-hours with mine and love it...
  3. Mad Mr H
    Mad Mr H
    Jun 10, 2005
    4,460
    London
    +280
    THE 800HD uses HD145 lenses as I understand.
    the Tac4 type were about 1.4 throw ratio...
    The HD145 as I understand are slightly less throw ratio...
    Guess at 1.3
    So for a 6 foor WIDE screen PJ front of lens would be 6x1.3 feet...
    The Manual has the full distance set.....
  4. brian aitken
    brian aitken
    Thanks guys for your responses,i will be ceiling front mounting the projector but is it 1.3 or 1.5 or 1.6 x screen width.I dont want to have to move it once it is up on the ceiling.
    Thanks Brian
  5. Mad Mr H
    Mad Mr H
    Jun 10, 2005
    4,460
    London
    +280
    Test it on the floor first and get it right.....
    You should always mount it with room to move it a bit.
    Check on floor is the only way to be right......
    Check the manual.....
    Do you have the manual?
  6. brian aitken
    brian aitken
    The manual does not state the throw distance from lens to screen centre which i think it should give a rough estimate.Also is there an additional bracket available that i could attatch the 800's bracket to so i would get the room to move it about a bit.
    Thanks Brian
  7. Mad Mr H
    Mad Mr H
    Jun 10, 2005
    4,460
    London
    +280
    Unistrut is your answer......
  8. Anders B
    Anders B
    Jan 11, 2005
    48
    +4
    ..My distance is 310cm/210 cm screenwidth=1,48. My raster size is not optimal though (for safety reasons.. hehe). With an optimal raster size I guess I could move it closer but this would not fit my hushbox. The size of the picture also shifts with the resolution of my scaler iScan HD. 960P makes the picture bigger than 576P. The manual on page 17-19 gives You the information, I think..
  9. brian aitken
    brian aitken
    Thanks MadMrH,I will check it out.
    Regards
    Brian
  10. brian aitken
    brian aitken
    Thanks Anders B,I will be using 720p for both pal and ntsc.I have now looked at the manual which i think should have been more detailed.Incidently who set up your 800 for you.
    Regards
    Brian
  11. chris9682
    chris9682
    Dec 17, 2002
    180
    manchester
    Hi Brian, if you are looking for someone to set up the 800 can i recomend Chris Frost. He has set up my seleco 700 three times and has done an excellent job on every occasion.
    regards
    chris
  12. brian aitken
    brian aitken
    Hi Chris, thanks for your tip i am now in talks with him to do that, hopefully shouldn't have to wait that long.
    Regards
    _____________
    Brian
