There are typically three important things to consider -
1.) Are you speakers wired correctly (+) to (+) and (-) to (-). This is more a problem with weak bass though.
2.) Where and how are you speakers positioned? The closer they are to a boundary wall, meaning the side wall and/or the wall behind the speaker, the more bass re-enforcement you get. But, it the speakers are too close, yes the bass goes up, but it also can become overbearing and muddy the midrange.
Also, and this somewhat applies to the next item, is the postion of the speakers in relation to the room. Turning the speakers slightly inward toward the prime seating location can completely alter the nature of the reflections in the room.
3.) Room acoustics; is the room hard or soft? A hard room has lots of reflective surface. A soft room has lots of soft surfaces like cloth cover sofas and chairs, curtains, acoustical tile, carpets, etc... that absorb and diffuse the sound.
A room that is highly reflective will have substantial bass peaks and nulls in the room. When a reflected wave encountera on coming wave and they are in sync, they re-enforce. When the meet and are out of phase, they cancel each other out and create a void in the sound location.
Try moving around the room, and listening to the bass, is it better in some locations and worse in others?
You can get some test tones here, but you must use them with common sense to protect your speakers.
http://www.avforums.com/forums/speakers/925527-audio-test-tones-several-sources.html
When using tones like this, you can isolate a low frequency, and hear the bass without all the clutter. Play low notes in the 20hz to 80hz range, and you will be surprised at how different the bass sound as you move around the room.
Again, especially with the bass sweeps, you need to keep the volume modest; nothing over 1/3 volume. And you need to stop periodically to give you speaker time to cool off. This also works best if you keep the bass control on the amp set to flat or neutral.
Also, consider that it is just a difference in the recording, some recordings have the bass emphasized.
Also, and this is related to item #3 above, you could be experiencing some type of room resonance. If you have wooden floor, sound could be transmitted down into the wood, and this could make the hole room (or just the floor) resonate at one specific frequency.
The solution to this is to NOT
couple the speakers to the floor. Rather,
isolate them. To isolate, you create an artificial barrier between the speakers and the room. What that really means is you mount the speaker on rubber. The rubber feet isolate the speaker from the floor.
This can be done in a variety of ways.
1.) Simply don't use the speaker spike on the floor. Just setting the speaker flat without spike might be enough to stop the resonance.
2.) Many in the group have had good luck with using a granite or marble food chopping board for the local general merchandise store, and the putting Deflex feet under them.
Deflex Polyurethane
Some might cut squash ball in half or something similar, but the goal is the same. To stop the speaker from sending sound down into the floor.
3.) Variations on a theme. There are isolation platforms that accomplish the same thing. Some are very expensive, but some can be had for about £40 to £50.
Here is another thread where some of the possibilities were discussed -
http://www.avforums.com/forums/speakers/1176676-reducing-sound-vibration-passed-floor-below-me.html
The same principles apply, but this thread applies those principle for a slightly different reason.
Steve/bluewizard
