Three HD Devices Into Two HDMI Inputs Wont Go!
G
georgedingwall
Hi all,
As there doesn't seem to be an end to the format war, I thought about buying both HD-DVD and BluRay players. I noticed that I could get one of each for around a total of 500 UKPounds.
However, my TV only has two HDMI inputs. And I already have a Sky HD Box on one of them.
Is there some sort of switching device where you can plug in three, or more, HD devices that will automatically switch an active line through to the TV?
I really don't want to be reaching behind the TV to change cables whenever I change from one format to the other.
Any advice will be appreciated.
Thanks.
7hil
If you just type in the word "HDMI" into Amazon you'll see that they do a switcher for £29.98.
G
georgedingwall
or get that new samsung duo player out next month.
I heard about that, but the price is probably going to be quite a bit more than buying one of each type of player.
Maybe the dual format solution will reach the mass market in a few years, but if history has anything to tell us, it is that the early versions of new technology are always very expensive.
Bye for now.
MI55ION
Here you go, an inexpensive switcher for your needs.
If you haven't already done so, you may also wish to consider some of the new gen AV receivers from the likes of Onkyo, Denon, Pioneer and soon to be released Yamaha AV amps all of which will have HDMI switching.
Owen824
that new samsung player looks like it is going to be £600 on launch. pretty good price considering it handles both formats as well as there online capabilities. definitely will go for one of these over buy two seperates. not enough space for 2 more seperates. :eek:
G
georgedingwall
Hi Owen,
My TV, A Bravia KDL40W2000, only has two HDMI inputs. I will never use it for games or anything other than watching TV and DVDs, so as long as I have a way of connecting more than two HDMI devices, I'll be happy.:thumbsup:
I currently have a Sony DVD/Hard drive recorder on the TV, and the SKY HD is being installed tomorrow. I want to keep the Sony DVD recorder attached to the TV, so will definitely need a switch to add more HDMI devices. So, whether I choose two separates or wait to have a look at the new Dual Format Samsung, I will still need a switch.
Bye for now.
nm10721
these are available cheaper on ebay. I bought one from the states for about £30 delivered and it was faulty on delivery. (lesson learned about importing). I now have a joytech box, it works fine,
Neil
Kevo
Shouldn't a switch that is HDMI v1.3 compatible be considered, or is it early days?
That reminds me, mine is v1.2 :rolleyes:
Also consider at leats one with 4 inputs AND optical audio inputs (you just never know what lies ahead). This time last year I was using one HDMI input, now i'm using 3 and I wouldn't rule out a 4th with the Xbox 360 elite :rolleyes:
Markatlarks
HD DVD output to LCD Projector and HDTV?
I have just being reading an excellent review on the Toshiba HD-XE1. Looking at the outputs on the back I notice that there is only 1 HDMI output.
With this in mind can someone advise me as to the best solution so I can either output to a Toshiba HDTV which has 2 HDMI ports and at the same time / or switchable output to an LCD Projector which has a DVI interface. I should point out that I will be upgrading to an HD LCD projector but will be using the DVI cable which is already installed in my wall!!!
Any help or advice will be much appreciated.
PS: I Have a Pioneer 7 channel amp but this does not have any HDMI or DVI passthrough / connectors.
TrevorS
Not a problem! Just as HDMI switchers are available, so are HDMI splitters, and also a combination of both (eg. 4in/2out => 4x2).
My setup feeds my HD DVD HDMI to an HDMI receiver which feeds a splitter for both a TV and a projector.
Here's an example of a 4x2 switch: http://www.ramelectronics.net/html/EXT-HDMI-442.htm
andybedz
Kevo
What version of HDMI does the THOR switch box handle?
Does it matter at this stage if it's not v1.3?
Also, I assume it's the same 'Thor' tht produces quality cables?
