My current setup is a Windows Home Server v1 as my storage solution, with a Revo running XBMC as my media PC.
This setup has served me well for many years, but I’m now looking to upgrade it. Firstly my WHS box is starting to run out of steam - it only support drives up to 2Tb, and is also starting to get a bit long in the tooth generally – it has been on 24/7 for about 5 years, so I can’t complain. Secondly I’d like a bit more choice at the client end. The Revo has been great, but I’d like a bit more flexibility in getting the content onto other screens, including remotely. I’m a tentative believer in the Chromecast, and being able to throw content around without relying on a fixed PC is pretty appealing.
I’ve had a play around with Plex and I quite like it – I miss some of the tuning I can do with XBMC, but out of the box it works well and is very easy.
One challenge in increasingly flexibility is codec support – most of my content is MKV, and that’s not generally going to be natively supported by a non media PC solution. I’ve toyed with transcoding in Plex, and whilst the works in theory, in practice its not really useable with HD content with my setup. As such my understanding is that I need to go with one of these options for any replacement:
1. Use a client device with proper codec support and the necessary grunt – a media PC in other words, same as I have today.
2. Transcode on the server. Maximum flexibility and least devices needed, but requires a decent CPU in the server.
3. Run a separate transcoding PC as well as server – no need for a separate media PC as such, as I can then throw it to a Chromecast, but replacing that with a PC for transcoding seems a it cumbersome.
I had been considering Synology as a replacement for WHS, but that’s not going to be any use for transcoding either, and to be fair, I don’t really expect a dedicated NAS to be that powerful, as its not its core function.
Is it practical to try to build a NAS / server with the power to do the transcoding, or do I realistically need to either give up on it completely, or else use a dedicated PC to handle that?
Any input or advice much appreciated...
