thoughts on bi-amping
Discussion in 'AV Receivers & Amplifiers' started by gilmore, Apr 15, 2003.
  1. gilmore
    gilmore
    I was thinking about adding another NAD 320BEE or the C270 to my existing 320BEE to bi-amp
    What are peoples views on bi-amping.. ie is it better to do this as aposed to buying a better intergrated amp?!
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    bi amping certainly works but it might not be cost effective, depends how much you value you old kit. I would take the opertunity to bi amp with a better amp rather than another 320
  3. sounddog
    sounddog
    Dec 11, 2002
    3,440
    107
    Leicestershire, UK
    +477
    With your two options, I don't think adding another 320BEE would be very cost effective.
    The C270 would add a lot more ... but a better option might be to replace the 320 with the C370, or a competing amp such as the Rotel RA-02 or Arcam A75+.
    Vikki
  4. gilmore
    gilmore
    thanks for that... I think an amp upgrade may be on my list soon then
  5. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Bi amping is ok,but in my opinion,a better option is a better amp,rather than 2 similarly specc'd but relatively low powered amps.....better to wait and buy one really good one!...I know having bought a few duffers over the years.
