Those double mono airline adaptor widget thingies...
Discussion in 'Headphones, Earphones & Portable Music' started by engaged, Aug 18, 2004.
  1. engaged
    engaged
    Jan 12, 2004
    179
    Edinburgh
    ...anyone know where you can get them from? Want to be able to use my own headphones when I flyto Oz in three weeks!
    Ta.
  2. engaged
    engaged
    Jan 12, 2004
    179
    Edinburgh
    Problem solved thanks to adb at Hi-Fi Choice forums - part RE05F at Maplin.
  3. potfish
    potfish
    Apr 8, 2003
    389
    Bristol
    +5
    Thanks for that, I was just about to ask the same thing.
    Don't suppose anyone can tell me the pinout though could they? I have searched the web to no avail.
    What I would like to do is build a Y cable with one stereo socket to two mono plugs. After more than one flight where I've had to stretch and squeeze the two mono prongs to try to get left and right working at the same time, I imagine it'd be much easier to ensure good contacts if the two mono plugs were independent from each other.
    Martin
