Uridium
I'm sure most have come across at some point those AVI's that just refuse to stream and just give you an "Unsupported Data" error on the PS3; quite often Gspot reports that they are encoded using a supposed PS3 compliant codec which is even more annoying
Just wondered if anyone can recommend an app that you have used to successfully re-encode these DivX/Xvid AVI's (even if it's into a newer codec of the same type)?
