thor v monster ?
Discussion in 'Cables & Switches' started by randomcdg, Jan 16, 2005.
  1. randomcdg
    randomcdg
    hello , anyone got any views on scart cables for hooking up sky + and dvd to a new samsung plasma tv, been looking around and ive found two possibles firstly there's a 'monster' scart from currys @ £55 :eek: or the simalar 'thor' version for about £20 .Or has anyone got any advice on a better way of doing this? Ur views would be really appreciated, anyway thanks in advance CDG
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Yeah, go and get a Belkin one for £15 and buy some DVD's with the change :)
    Look back through the previous postings re the benefits (or otherwise) of expensive cables.
  3. nwgarratt
    nwgarratt
    May 5, 2002
    26,335
    +2,840
  4. imr4n
    imr4n
    Jan 16, 2005
    How much of a difference will the thor scart lead make?
  5. Peridot
    Peridot
    Aug 24, 2004
    2,913
    Newport, South Wales
    +285
  6. imr4n
    imr4n
    Jan 16, 2005
    How good is the hittachi scart?
  7. Peridot
    Peridot
    Aug 24, 2004
    2,913
    +285
    I've used the metal bodied one and the cheaper plastic bodied one and found them both excellent in terms of build quality and performance. Given the law of diminishing returns on cables, and the inherent limitations of the SCART connector, it would take a lot to convince me that it's worth spending any more.
    _________________________
    Dermot
  8. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    its ok, dnt notice a fair change in picture quality tho.
  9. randomcdg
    randomcdg
    cheers for advice everyone, went for 'hitachi' from argos :clap: ,laterz 4 now -CDG
  10. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    waste of money, cancel your order and get an ixos one from tvcables for cheaper than that...
  11. imr4n
    imr4n
    Jan 16, 2005
    randomcdg, did you get the hitachi cable and is it any good?
  12. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    ive got the same cable (use it for freeview) no diffrence in using a scart half its price.
  13. nwgarratt
    nwgarratt
    May 5, 2002
    26,335
    +2,840
    It isn't worth using a cable like the Hitachi or Thor with Freeview. They are worth it when using a decent DVD player and TV/display device.
    I only use a £4.99 cable with my Freeview. It is still OFC etc like more expensive cables.
  14. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    Good QED Sqart RGB only one is the best I have found for dvd. Was an improvement over the Thor cable I had. The thor was still a good cable though.
  15. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    well it is what i used to use to connect my dvd to the tv until i got a monster cable now the monster cables taken its place, its useful for freeview
  16. imr4n
    imr4n
    Jan 16, 2005
    The hitachi cable did not make any difference at all. Returning it tomorrow.
  17. theo cupier
    theo cupier
    Sep 18, 2004
    1,649
    63
    Amersham, Bucks
    +113
    I've got a Cambridge Audio Premium Scart, a Thor from Play.com and a Monster Scart 1.
    One of these goes from my Joytech scart switch box to the TV, one from the DVD player to the switch box and the other from the Sky box to the switch.
    Obviously my switch box -> TV needs to be the highest quality lead since everything will travel down it. Any ideas on which of my 3 leads this would be?
    Next best lead would be for the DVD -> scart box so it gets the best overall path to the TV with the Sky -> scart box being the least important (in terms of my viewing priorities anyway)
    Anyone care / date to attempt to put those 3 Scart cables in order of quality? Or do you think they will all be about even?
  18. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    what did i say, listen in future :rolleyes: :nono:
