I have upgraded my Thomson box,WD 500g hard drive and new PSU kit.
However about once or twice an hour the picture freezes just on recordings for one or two seconds anyone any ideas.![]()
Where did you get your power supply from?
Did you fit the star washer?
Same problem here... I upgrade to 1TB and Satcure psu upgrade!
I tried to contact them but they said send complete box....
Don't know what to do... I don't want to give my box to them for more than 2 weeks like psu...
Hope someone know solution to this issue...
I've seen a lot of talk about the Star Washer - how imporatant is it? I got my PSU ready built from Digifix and there was no washer. Where does the washer go?
It goes under the psu board and screw fixing at the top left beside the power connection.![]()
Yep.I'll get the screwdrivers out - I have a washer somewhere... Is it for earthing?
Yep.
By the way done a full reset and have lost series link and box office help.![]()
I sometimes get a little glitch and momentary loss of sound at the point of a second recording starting or finishing,
e.g. If recording a 9-10pm programme the box will record from roughly 8.58pm to 10.02pm. If I watch a programme recorded at 10pm it may 'glitch' about four minutes into the recording, at the time the other recording finished.
Since i have mentioned the problem it has not done it all day,on any recording.![]()
Have you tried a planner rebuild or forced update?Same here, but an old problem of mine has resurfaced, which is the epg not responding to remote or receiver commands.
I need to plug out at the mains to get going again![]()
Have you tried a planner rebuild or forced update?![]()
