RogerFinch
hey everyone
I've upgraded from a Panasonic TU-DSB30 digibox (which was freezing,) to a Thompson Sky white box, and am now getting wavey lines diagonally over the screen, even in the menu.
I've swapped the scart cable, the scart port on the back of the Sony LCD, removed all the ariel and other cables just in case. Gone in the installer menu and turned off RF power and changed the channel number. Nothing stops the lines scrolling up and across the screen
If I put the Pany back on, it's fine.
If I am on the menu watching the wavey lines and remove the dish input, the wavey lines stop - so is the signal too strong?
Help!!
Help!!
