My Lyra jukebox is only about 2 months old and was working fine until a few days ago. Now the thing wont turn on, it freezes on the 'Thomson Lyra' screen and just stays like that for 10-15 mins then turns off. I tried upgrading the firmware but the computer wont recognise the player anymore :-( Does anyone know how to fix this? Thanks in advance
If it just happened on it's own I would get in touch with the place you bought it from and ask them about a replacement. You didn't format it from Windows did you as that can screw up a lot of mp3 players ?
Yeah i formatted my computer once, but im sure it was working after i formatted the comp. But yeah it happnened on its own, one day it just wouldnt turn on (after a long time not using it)
As long as you didn't format the MP3 player then you haven't damaged anything so can send it back. Do they have a technical support line that you can ring ?
