dmjohnson123
Established Member
Hi all.
I have a Thomson DTI1000 freeview box with RGB Scart Output.
I want to occasionally connect this up to my new Sanyo Z3 projector for the occasional movie/sports event etc.
This would be only occasional use and therefore I can't justify spending a lot of money on converter boxes etc.
I need advice on what is my best option in terms of a relatively cheap cable to go from RGB scart to either component/S-video/VGA.
The cable would be 5m long so what connection method and cable should I buy ?
Thanks in advance for your help
