Hi Does anyone know if it is possible to get a component or S video output from either of the scarts on on this unit, I would like to connect to my DVDO HD scaler and then on to a crt projector. Also what type of lead would be needed. Thanks Ps The same question for my Amstrad Sky digibox.
Hi It is the HD but the freeview box is a DTI 2300. If this would work what type of lead would I need.
scart to 4 phono.......http://www.tvcables.co.uk/cgi-bin/t...d_group/se=Scart Leads/op=eq.html?id=Ia4yXmg7 and it uses the component input and a composite for sync......... need to read your HD manual for instructions on using using RGBS input
