Thomson DTI 2300 - Moved and can't watch Freeview
Discussion in 'Freeview & YouView' started by sibyllemarie, Sep 20, 2005.
  1. sibyllemarie
    sibyllemarie
    Hello,
    I'm completely new to the forums, I hope someone can help me. Last year I bought the Thomson DTI 2300 receiver and it worked fine. However, I didn't use it for the past 3 months. When I moved I tried to connect it, but after finding out that the house is subscribed to NTL I bought an aerial that is supposedly working with Freeview. However, the box does not connect to the TV properly and doesn't react to the remote. The only button working is the power switch. The green light is on, the cables are connected but I don't get any signal from the box. It showed the error code No Channel before, since I switched it off and on it doesn't do anything. My area is supposed to have Freeview. Does anybody have an idea what I could do? Any help is MUCH appreciated.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    where and when did you buy it?
  3. sibyllemarie
    sibyllemarie
    From the Comet website, about one year ago. Will hunt for the guarantee but not sure if I still find it in all those moving boxes...
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    try your email inbox, also have you tried unplugging from power for 5 minutes before plugging back in and trying again
