thomson dti 1000 receiver, your verdict
Discussion in 'Satellite TV, Sky TV & FreeSat' started by VERGIL7, Jul 11, 2003.
  1. VERGIL7
    VERGIL7
    to all of you who have posted on the forums, and have
    the thomson dti 1000 receiver . would you please post your
    verdict on this receiver, and let me know how good or how bad
    it compares with other freeview digital receivers.
  2. johnski
    johnski
    Picture quality is pretty good, quite fast at changing channel, has rgb loopthrough, dont know how it compares to other receivers, only ever had the thomson, BTW woolworths have this for 89.99
    cheers
    johnski
  3. ff2001
    ff2001
    Jun 19, 2003
    36
    Leamington Spa
    I was getting a poor picture with sky on my amstrad DRX300.
    Did a comparison between the thompson and amstrad and found no noticable pq difference. Poor picture not down to box but the source.
    Lee
  4. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +149
    I get an excellent pic & sound.
    Easy to navigate around.
    You can re-order your favs tv guide (but not re-number).
    Have to manually swicth off/on every couple of weeks as digital text seems to gor astray!
    Recommended.
  5. BigAde
    BigAde
    Jul 22, 2002
    1,025
    East Sussex
    +30
    I have the Thomson box...
    Good pic, good sound, very good on paper but...
    Suffers from occasional lock-ups which require you to unplug/replug from the mains. Picture & sound breaks up occasionally, but this may be due to signal rather than box. Box sometimes doesn't respond to the remote (fault with box rather than remote since my programmed Marantz RC2000 MkII suffers the same problem with the box at the same time).
    Have read numerous reports on this and the Digital Spy site, it seems the consensus is the Nokia 221t is better, but the Netgem Iplayer is the best box. Up to you, 80 quid buys you a cheap, good Thomson which is more than fine for the money. 130 quid buys you either the Nokia or the Netgem. Personally the faults of the Thomson annoy me enough that I would buy the Netgem if I was to buy another box tomorrow.
