Thomson DTI 1000 DTT box - remote
Discussion in 'Satellite TV, Sky TV & FreeSat' started by BillyNomez, Jan 7, 2003.
  1. BillyNomez
    BillyNomez
    -above freetoview digital box has a remote with keys that look like they should either glow in the dark or light up i.e translucent rubber pads, even says NaviLIGHT system at the bottom of the remote but..
    cant/wont light up and dont think it will. Missing something fundamental here or trades description act ???
    BR BN
  2. fuzzy
    fuzzy
    Sep 8, 2002
    40
    ive got one of these and my keys don't light up either
  3. WSH
    WSH
    Apr 13, 2002
    997
    28
    +39
    navilight is thomson speak for easy navigation. Nothing to do with glowing or bulbs.
  4. Mr Rob T
    Mr Rob T
    Nov 13, 2002
    150
    Rotherham
    I also have this box. I am not sure if this is the same on other manufacturers boxes, but there is no button to turn on and off subtitles, and this had to be done from the menu.
  5. lightningvictim
    lightningvictim
    Sep 3, 2002
    201
    Stonehaven, Kincardineshire, Scotland
    +11
    I bought one of these for my mums Christmas present - she is complaining that when it is raining/snowing she gets a lot of "Bad Signal" messages. When the weather is fine she has no problems....
    Any ideas?
    She has a large aerial in her loft but some people have suggested that the FTV boxes require an outside antenna?
    Any comments?
    Les
  6. BillyNomez
    BillyNomez
    Thanks WSH for the info on Navilight or Nolight as the case may be....
    Am running the DTI1000 free to view from an indoor loft aerial so no the aerial doesnt need to be outside,
    the cause of Bad Signal could be signal strength, can anyone enlighten me does the message appear if a station is off-air or can it happen to the regular 24hour channels with a poor incoming signal thus nothing recieved ?
    BR BN
