Thomson DSI 4210
Discussion in 'Satellite TV, Sky TV & FreeSat' started by madcyril, Jun 6, 2005.
  1. madcyril
    madcyril
    May 30, 2004
    1,026
    Manchester
    +94
    Can anyone tell me if I can output SVHS from Scart on the above digibox so I can connect it to my Amp,if not what are my options.
    Cheers.
  2. Bluevanman
    Bluevanman
    The scart socket on the box will only output RGB or PAL.If you want S-video output you will have to get either a Sky+, or one of the old Grundig boxes, some of which had an S-video output.Look for a model number that ends /2
