Thomson DPL907VD !!!
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Bobby777, Nov 14, 2004.
  1. Bobby777
    Bobby777
    Any ideas on this one? I've tried the other Thomson hacks, but nothing works so far.
    Thanks!
  2. lesand
    lesand
    have you had any luck with multiregion code for thomson DPL907VD. HAVE LOOKED EVERYWHERE BUT NO LUCK AND OUTLET DID NOT HAVE OR WANT TO FIND CODE. LET ME KNOW IF YOU DO PLEASE...LES :lease: :lease:
  3. mushanakoji
    mushanakoji
    i'm looking for an answer... is there anything? :confused:
  4. Bobby777
    Bobby777
    Press "Open"
    Type "123456"
    Change the region with the volume.
