Thomson DHD4000 - Recording
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Skumball, Jul 17, 2005.
  1. Skumball
    Skumball
    Jun 21, 2005
    We have just purchased the Thomson DHD4000 and it seems pretty good. Recording from the program guide worked fine so no problems there, but when I just want to press record, why does it not work how it should?
    Tapping REC does not work. Holding the button down doesn't always work. Holding the button down and waving it around does work after a few seconds! I know that the box is receving the signal due to the led flashing so what's up with that?
    Then when it IS recording I can't get it to stop. The STOP button doesn't work. The only way to finish recording is to go into the Record List and remove the entry which seems a little cumbersome. And as far as I can tell it will stop recording at the end of that particluar program. Is there any way to make it record non-stop until manually stopping it?
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You're not using it with a plasma screen by any chance ?
    Plasmas give out a lot of infra red from the screen, and it sometimes floods the receptors of infra-red controls, causing malfunctions.
  3. Skumball
    Skumball
    Jun 21, 2005
    Fraid not. We have a Sony CRT.
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Oh well, another theory out of the window :D
  5. ad47uk
    ad47uk
    Apr 21, 2005
    749
    +6
    You must stiil have the old software, Sunday it should download the newer software, which will allow you to just press record. I think the software will be downloaded sunday and Wednesday.
    I had the same probglem with mine.
  6. Wig
    Wig
    Did your issue get resolved? I'm wondering how you find the DHD4000?
