Thomson DHD-4000 overheating
Discussion in 'Digital TV & Video Players & Recorders' started by DPhil, Nov 22, 2004.
Tags:
  1. DPhil
    DPhil
    Nov 8, 2004
    29
    I have just bought a Thomson DHD-4000, it works fine for a while but then locks up, sometimes losing picture and sound, sometime just losing picture but keeping the sound.
    It is in my A/V cabinet, plenty of room around it but with some other kit in there - AV amp, DVD and VCR.
    I can cure it by leaving a household fan running and pointed at the unit in the cabinet - it will then run all night!
    Does anyone have similar experiences or is this likely to be a faulty unit?
    I'll return it, but need to know whether to get a replacement or a refund.
    Thanks for any advice.
  2. davidredge
    davidredge
    Sep 26, 2004
    44
    I was reading about this model earlier - i'm in the process of buying a PVR and doing some research...
    Apparently, the 4000 does overheat, likely due to the type of hard disk used, so its not a faulty machine, just the design.
    Our old video used ot over heat in the TV unit, so we cut most of the rear out and that sorted it. Try just getting air in, save on the fan being used!
  3. Ged
    Ged
    Apr 29, 2002
    920
    +17
    Stick with this, it is far more stable than the Twin, try moving your kit around and increasing the air holes if poss in the cabinet.
    Mine works well, only suffers from the reported gripes which can easily be worked around.
  4. DPhil
    DPhil
    Nov 8, 2004
    29
    Thanks - I'll try to get more air around it, although it is so hot, I think I may need to build a PC case fan into the back of the cabinet!
    I do like the unit, the picture quality is amazing and it's easy enough to use.
