thomson 643s
Discussion in 'TVs' started by coolio2k2, Oct 2, 2004.
  1. coolio2k2
    coolio2k2
    ive just got one of these tvs but whenever i connect anything to av1 (rgb) it just stays black till i change it to video instead of rgb same with av2 (rgb) can anyone help ?
  2. Pug72
    Pug72
    May 10, 2003
    1,992
    Hereford
    +277
    You will need fully wired scart leads.
    The source must be outputing RGB.
  3. coolio2k2
    coolio2k2
    its a ps2 and xbox ? and them digisenders ?
  4. Pug72
    Pug72
    May 10, 2003
    1,992
    Hereford
    +277
    Have you got RGB leads for your consoles?
    The leads supplied with the consoles are composite leads that plug into a scart block adapter. They aren't RGB.
