Thomson 40KW611S Rear Project
Discussion in 'Televisions' started by garbon, Jun 29, 2003.
  1. garbon
    garbon
    :confused: Has anyone had experience of Thomson 40KW611S ?
    How is the picture? not bothered about sound as I have Sony amp.
    How many of the 3 scarts ar RGB?
    What are the aspect ratio options like (I have a Sony 32" at the moment and I like the 'smart' option)
  2. redlouie
    redlouie
    Had this set deliverd last week from Powerhouse for £900 !! this is my first RP. As expected the picture is not as good as CRT but certainly appeared as good as most Tosh which always seem a bit wishy washy to me. The Virtual dolby is not great athough another sound setting 'Magic' is better, intend to rectify by replacing my exisiting DVD with a 5.1 home cinema DVD. The definite plus is the stand which fits underneath and has a glass DVD/Video shelf making it look pretty neat unlike most RP's which either have no shelf or pretty poor looking ones. All in all I am very pleased with the set might not be the best RP out there but for the money can't argue with 40" worth.
