Thomson 32w643, vertical bands
Discussion in 'General TV Discussions Forum' started by Pug72, Aug 31, 2004.
  1. Pug72
    Pug72
    May 10, 2003
    2,058
    Hereford
    +299
    I have had this set a week now and am almost happy with it.
    Geometry isn't top notch but passable.
    DVD via PS is stunning. Sky is as good/bad as I expected and the xbox is also stunning.
    The only problem I have is dark vertical bands/smears the length of the screen.
    They aren't noticeable on non-moving pictures, but when there is movement on dark scenes they become apparent. This happens with all sources, PS RGB and the front composite.
    What is it?
    Is it easily sorted?
    What about leaving the set with a static bright image for a while?
    Will it sort itself out? What actually is it?
    I may be able to live with it but would love to remove it.
    I really don't want to go through the hassle of repacking the set and getting it replaced just in case the replacement is the same.
    Cheers.
  2. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,132
    83
    Over the Hill & Far Away
    +119
    I found this only happened (again only very rarely) when the brightness was way up... once I had calibrated it properly.. I have never seen them since...also I have pretty much sorted the geometry with fiddling in the setup menus.. took a while but its nearly perfect...
    Matt
  3. Pug72
    Pug72
    May 10, 2003
    2,058
    Hereford
    +299
    I've tried everything from bright settings to dark settings and they are still there.
    Trying to ignore it but can't.
    Could you give an idea of your settings so I could try them please.
    Thanks.
  4. SimonY
    SimonY
    Mar 24, 2004
    36
    Cambs, UK
    Have you tried turning down or even off 'Expand Contrast'?
  5. Pug72
    Pug72
    May 10, 2003
    2,058
    Hereford
    +299
    Unless it's possible to turn it off in the service menu, you can only choose low, medium or high.
    Is this in the service menu? Will it fix it?
  6. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,132
    83
    +119
    I set contrast expand to low, noise reduction off and the custom settings to approx :
    Colour 50%
    brightness 50%
    Contrast 70%
    HTH
    Matt
