Thomson 32LB220B4
S
spur4awin
Someone on this forum who has some experiense of this thomson Lcd ?
looks like it has good specs:
Contrast 800:1
Brightness: 550
Fall time : 8ms
raise time: 8ms
double tuner
virtuall dolby surround: 2 * 12w + 16w
3 scart + dvi (hdcp) ,s-video
C
cyberdude
Did you ever get any more information about this LCD TV? I am considering getting one but cannot find any reviews or opinions anywhere. The specs look good on paper.
Is it 15/9 or 16/9? I've seen conflicting specs even on Thomson own web site.
mooseepoo
Does anyone know anywhere that is stocking this TV?
I am very interrested in it. It looks a fantastic bit of kit!
Does anyone know if it can be wall mounted?
C
Corelli
I had the Thomson, but returned it. I now bought a Hitachi 32LD7200.
It is a true 16:9 display.
The picture quality is very good, very crisp, clean and natural. The presets are crap, for my taste, but with a little tweaking you can do a lot. All details in dark and bright areas are visible.
It has two fans, which I didn't notice with normal sound level. My Xbox is twice as loud.
The plexiglas pane looks cool but is pretty reflective, so place your lights beside or behind the set.
Although not mentioned on the website and the manual, it has 14:9. But in 4:3 or 14:9 mode the edges of the picture (of course in these modes there are black bars left and right) are not clean as with other panels. There is a glowing strip of about 4 or 5 pixels.
The backlight isn't very even (or well-balanced? I'm german...). After running for about 30 minutes, you can notice brighter light in the lower left and upper right corner of the screen.
Now the reasons for dumping it:
1. HD ready: I tested all resolutions via component - everything ok. But later I got a Samsung HD745 DVD, which has DVI and can upscale to HD res. With 720p/50Hz the Thomson only displays in black&white. I tested the Player with other sets (Philips, Acer, Hitachi) - full color there.
2. You cannot switch Aspect Ratios when in ANY HD modes. With 720p or 1080i this is ok, because these modes are always 16:9. But some Xbox games are 480p and 16:9 (480x853), others are 480p and 4:3 (480x640). When playing 4:3 games in HD, you always get 16:9, which means totally wrong proportions. My Hitachi does the job without problems.
If there is another question, just ask.
C
cyberdude
Thanks for your views on the Thomson. I saw the 27" version in a store and the picture did indeed look very good - even better than some of the more expensive Philips along side, but I did wonder about the glass pane and how reflective it would be.
Does the TV have progressive scan? I don't play games so the lack of switching aspects in HD is not a problem. I cannot comment about the black and white in HD as I don't have any equippment capable of HD at the moment.
Your first comment about it being true 16:9. Is that referring to the Thomson or Hitachi?
C
Corelli
The specs say: 'Vertical frequency: progressive'
Is it that what you mean? Is there any LCD without this feature? I thought this was part of the LCD technology in general.
And yes, the Thomson is 16:9 with 1368x768, although some (official) datasheets are contradictional. I don't know how they let this happen. They did not correct this until today.
C
Corelli
mjbower said:
whats your view on the Hitachi ? would you recommend it ?
Definitely! I can only say: WOW! This is some panel. I had to pay about EUR 100,- more than for the Thomson, but I am glad I did so. Ok, this doesn't sound very neutral. But to me it is the best LCD-Picture I have seen so far, and as far as I know it is the only IPS Panel on the market at the moment. But maybe I'm wrong with this...
Since this is a Thomson-thread, I will stop here. There are Hitachi-topics here, and Ii think there are a number of people who like the 32LD7200 as much as I do. BTW - no backlight buzz with my set.
Puffer
I must say I like the look of the Hitachi 32LD7200 Correlli
epigout said:
Le jugement de la Fnac :
Thomson insiste a nouveau la ou beaucoup de LCD pechaient auparavant, a savoir le son, avec le DPS+ qui le traite via des haut-parleurs en titane, et un caisson de basses integre. De quoi procurer de belles sensations lors des DVD et autres sources explosives. Lfimage est quant a elle servie par le systeme Hi Pix HD. Le tout est servi par une connectique tres complete, permettant la compatibilite TV HD. Enfin, le design bicolore avec la finition noire laquee est tres qualitatif.
Diagonale de lfimage : 82 cm
Dimensions sans pied : 945 x 580 x 125 mm
Poids : 23 kg
Tests labo
Luminosite : 305 cd/m2
Contraste : 564 : 1
Temps de reponse :
20 ms
Qualite tuner : 13,3/20
Note technique
Bot translation from the pdf:
The judgement of Fnac: ''Thomson insists again where much LCD fished before, namely the sound, with DPS+qui treats it via titanium loudspeakers, and an integrated box the low ones. What to get beautiful feelings at the time of the explosive DVD and other sources. L ' image as for it is been useful by the system Hi Pix HD''.
''The whole is been useful by a very complete connector industry, allowing compatibility TV HD.Enfin, the two-tone design with the enamelled black completion is very qualitative''. I hope you could understand some of that . :confused:
Contrast 800:1
Brightness: 550
Fall time : 8ms
raise time: 8ms
double tuner
Note different specs :
''Diagonal of L ' image: 82 cm Dimensions without foot: 945 X 580 X 125 mm Weight:23 kg Tests laboratory Luminosity:305 cd/m 2 Contrast:564:1 Response time: does 20 ms Quality tuner:13,3/20 Note technical??? '' .
They only rate it with *** on FNAC and it seems pricey here in UK .
Puffer .
C
cyberdude
I think I'll take a closer look at the Hitachi too. What I liked about the Thomson is the PIP feature which is not available on many LCD displays at this price level. Also liked all the connection options.
