Thomson 28WT25US
Discussion in 'Blu-ray & DVD Players & Recorders' started by Des Horrigan, Apr 5, 2001.
  1. Des Horrigan
    Des Horrigan
    Does anyone know of a multi-region hack for this TV/DVD combo? Is it the same hack as the other Thomson DVD players?
  2. Guest
    It is possible to make your TV/DVD combi multi-region and if I remember correctly you need to do the following
    Hold down 'OK'/'eject' and 'f/foward' simultaneously for about 5 secs and hey presto it will be multi-region.
    I'm 99% sure that is the correct method, if it's not let me know and I'll get you the correct one.
    Good Luck :eek:
