Thomson 27LB125B5 HD READY
Discussion in 'LCD & LED LCD TVs Forum' started by SLIM, Nov 3, 2005.
Tags:
  1. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    OK guys anyone here got the new Thomson 27LB125B5 HI-DEF set. I have done a SEARCH but ther is only like 3 threads come up. And no info on it so in the dark with them.
    Any way the set is a
    Thomson 27LB125B5
    Black with silver base.
    27in (68.5cm) TV with 67cm visible screen size.
    Resolution 1280 x 720 pixels.
    Brightness 550cd/m2.
    Contrast 900:1.
    Virtual Dolby surround sound.
    2 x 16w RMS music power output.
    Fastext.
    UHF and VHF tuners (Pan European).
    Auto setup.
    Auto search tuning.
    Auto search sorting.
    Auto search labelling.
    HD ready.
    Compliant to EICTA (HDMI).
    PC input via VGA - suitable for use as a PC monitor.
    3.5mm headphone socket.
    Audio in, video in, s-video in, HDMI, YPrPb and CrCb located at rear of unit.
    1 SCART socket.
    Remote control
    I can take it back with in 16 day's for a full ££££ refund and its only going to cost me £499 :smashin:.
    So what you guy's think ??
  2. jtorry
    jtorry
    Nov 8, 2001
    523
    Mine was sent back because it was awful at handling moving images across the screen. Lots of smearing and alike meant a really good TV was made unusable. When playing FIFA 06 as a test, it was so bad I began to feel sick. As far as looks go it is great and I was really disappointed to have to return it. I got mine for £600 about 6 weeks ago. Just in case you hadn't checked the Thomson site for the specs it doesn't have an HDMI socket, but the DVI is HDCP enabled.
    Oh and the set I got was a Thomson 27LCDBO3B. The other model number doesn't exist on the Thomson website.
  3. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    Hello m8 thank's for that do u think you could of hade a faulty unit ?.
    AS its got a 8ms Respones Time
    I bean told that theres a 35 day's waiting time for the set so maybe there updating it i dont know lol.
    CLICK HERE THIS IS THE SCREEN
    All so u have any pic's of the set thanks
  4. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    DUDE the model number to the set you got was the older model from 2004.
    So i wonder if there REBADGING old units :confused: :thumbsdow
  5. jtorry
    jtorry
    Nov 8, 2001
    523
    well that is actually a different set to the one I got. I got mine from argos and although the model what the one you have linked to it actually turned out to be another one. Mine had a glass front to it as well. Might be worth a look as the specs look great for £499
  6. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    Ha m8 you got any pic's
  7. jtorry
    jtorry
    Nov 8, 2001
    523
    no pics sorry. My only worry would be that they say the TV can be replaced with another model at the bottom and you may end up with the older model which I got. I eventually got mine returned based on the fact that the argos site lists the TV with an HDMI socket which the TV does not have. If it was not for that fact I would have been stuck with it as they were insisting on a engineer visit.
  8. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    I have bean told that i have a full 16 day's to get my money back In full no QUESTIONS asked. And i can get my money back at any time before the unit get's to me
  9. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    You might want to read this thread. No offense but I think you would be making a big mistake by buying that set. :lesson:
  10. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    moogley its cool m8
    what part the bit about you get what you pay for ?.
    If so then this set should cost £800 but as side can get it now for £500
    IF you on about the picture quality then that's not realy a problem as its not for tv realy its for xbox 360 and the pc
  11. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    ok placed my order to day for this set should be with me on 11/11/05. If the screen come's with the model number Thomson 27LCDBO3B then i will send it right back ASAP as ( jtorry ) side it was CRAP if its the Thomson 27LB125B5 then i will give it a go.
    Oh i hade got it from argos to if thay try to kick up a fight then i will just tell them its not the set i payed for as i payed for Thomson 27LB125B5 and not the lower spec Thomson 27LCDBO3B from what i bean reading the Thomson 27LCDBO3B is not HD at all. So i will have them then lol.
  12. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    ( jtorry ) Was the model number on the side of the box are the back off the unit its salf ??. as if its on the unit im going to try to get the guy's to stay as i open it up.
  13. jtorry
    jtorry
    Nov 8, 2001
    523
    was very clearly marked on the box.
  14. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    Nice one m8 did the guys just go right a way are what ?. If its the same model as the one you got i will try to get them to take it back there and then
  15. Horace2000
    Horace2000
    Mar 7, 2005
    13
    3
    Nottingham
    I've decided to put some cash down on one as well. I thought about the price and looked into previous Thomson models, the majority of the 27in screens are always well received but do state they show grain on Analogue feeds, but switching to a digital feed from the RGB seems to remove this completely.
    As Slim has stated if we are unhappy with the Argos bargin it can go back as long as its in the 16 day period. I shall rig up my XBOX to check the response times and see if there is any major lag in the picture.
    If it turns out to be rubbish I'll just wait that bit longer for the Samsung to come down in price, which shouldn't be too long with there new model line coming out.
  16. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    Thats what i will do if its crap ill get a good one on boxing day
  17. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    Horace2000 what date you got m8 ?
  18. Horace2000
    Horace2000
    Mar 7, 2005
    13
    3
    Nottingham
    Not sure as I've not heard anything since doing my order!! I got the confirmation email but it just says please allow up to 35 days!!!
    Credit Card company have paid out the money so hopefully will hear something soon. I better!!!!!
    Slim was you called about the date or did they just email it to you
  19. DarkBytes
    DarkBytes
    dudes hello :thumbsup:
    Just to let you know I also ordered one of these babies on the 6th nov.
    Thing is i did it in store, there are leaflets in store showing this offer & others , the blurb on the leaflet indicates that they should normally deliver in 7 days.
    Only after you pay & you are given the receipt , you notice that it states the order can take up to 35 days.
    I rang the number on the receipt who confirmed this and stated that they will ring a few days before delivery ( They didn't have details of when the set would be in stock).
    They did tell me I can cancle at any time.
    Also more importantly :lesson: nowhere in store, on the offer pamphlet , or on the recicpt did it state that this model could be replaced with a different one , with lower contrast etc , as it does on there website.
    So for the highsteet buyer , I assume they can not apply this.
    Anyway , really looking foward to someone getting one of these and letting us all know how it fairs.
    Take care all
  20. Horace2000
    Horace2000
    Mar 7, 2005
    13
    3
    Nottingham
    I'm not sure how they can supply the same TV with a lower contrast ratio, surely it would be a different model completely??? Well before Christmas would be nice but before the 2nd of December will be excellent!!!
  21. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    I payed for mine in the shop on the ( 4/11/05 ) and then got home phoned them up and got a DELIVERY date for the 9 11/11/05 ) M8. SO i would say phone them up ASAP :smashin:
  22. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    Hello m8 phone them up and ask for a DELIVERY date thats what i did :smashin:.
    OK m8 when it comes to this DO NOT TELL THEM YOU HAVE SEEN THE WEBSITE Then you you have 100% DENIABILITY about that :smashin: .
    All so i dont think its on my self ARGOS trying to give us a OLD unit's from 2004 :thumbsdow.
    ( jtorry ) Hade a unit sent to him MODEL NUMBER 27LCDBO3B and this model is from 2004 HE SIDE THIS ABOUT IT
    ( Mine was sent back because it was awful at handling moving images across the screen. Lots of smearing and alike meant a really good TV was made unusable. When playing FIFA 06 as a test, it was so bad I began to feel sick. Just in case you hadn't checked the Thomson site for the specs it doesn't have an HDMI socket, but the DVI is HDCP enabled )
    :nono: WE say to ARGOS
    SO if the unit you get HAS anyothere MODEL NUMBER then 27LB125B5 / 27LB125B5U then its going to be a old unit So befor you get it out the box try to find the MODEL NUMBER on the net just to see how old it is.
  23. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    2 days to go then i should have my screen
  24. DarkBytes
    DarkBytes
    hey slim, will be looking foward to your results.
    btw heres a link ( lot of reading ) and some tests for lcd's
    http://www.techmind.org/lcd/
    i rang the number as soon as I got the recipt home on the 6th , but they where out of stock, at present they seem to be out of stock everywhere , well done for getting your delivery date on time :)
    btw can i ask , why you getting this thompson when you have a 42PD3000 ?
    cheers
  25. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    Hi m8 im getting the thompson for the bedroom and mainly for the xbox 360 :smashin:
  26. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    1 day to go guy's ill post pic's when it get it
  27. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    i should have my TV later on to day. Time it should be here is 7.30 am till 1 pm so post to come just after as long as i dont tell them its no good
  28. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    Ok the TV came to day and it is not the model that's in the book its model number 27lcdb03bbk.
    CLICK HERE FOR THE LCD
    Realy nice looking shame there is lots of crap in side the screen look's like water lol. OK i could not see any ghosting are anything like that but then i only hade it on for around 5 min. I was unable to get the screen to run @ 1280 x 720 My GFX card is a GF6800. Naw i have to give ARGOS 48 houres to get back to me with a pic up date :thumbsdow . The screen only has 1 scart
    as well :suicide:
  29. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    jtorry how long did it take to get ure £££ back thank's
  30. DarkBytes
    DarkBytes
    Slim ,
    thats gutting mate
    I think argos are being really cheecky offering one brand of tv and then shipping another.
    did they say anything when you called them up to complain ?
    its kind of weird, that the manual on the thompson site for the tv they advertise has DRAUGHT written on it, my guess is that Argos are waiting for thompson to deliver a bathc of the new models.
    Well I hope that is the case.
    Let me know how you get on mate
