T
Trickweazel
Just finished putting together a HTPC for the living room. I've got a Thomson 27LCDB03 and have connected it to the PC on the DVI connection. It's all fine and dandy apart from the fact that I cant get the PC to work with the TV at the TV's native resolution (1280 x 768). It will run at 1024 x 768 with the TV going into 4:3 mode without any problem but the moment you try to get it into 1280 x 768 and the TV into 16:9 it just reboots the pc and goes into a bootloop cycle.
The video card is an ATI Atlantis 9000 fanless but I have also tried it with an ATI Sapphire 8500 and get the same result. Has anyone tried running a DVI input from a pc into this particualr TV? anyone any ideas at all about the problem?
