Thomson 27" LCD: Loud buzzing from PSU
Discussion in 'LCD & LED LCD TVs Forum' started by Messiah, Jan 13, 2004.
Tags:
  1. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Any other owners experience this? So disappointing. Even on standard volume it is very annoying. Definitely from the PSU at the rear top left of the unit.
    :mad:
    This will be going back tomorrow.
  2. sponshagga
    sponshagga
    checked mine and there is a buzz although I hadn't noticed it before - can't5 hear it in the room. Only when I put my ear to the back - can't even hear it when i put my ear to the front.
  3. Guttee07
    Guttee07
    Sep 13, 2003
    64
    Runcorn Cheshire
    Make sure your backlight setting is on bright, mine did this when i put it on the soft setting. Think it's a bit like a dimmer switch in your house as they buzz when not feeding full juice. This solved mine as it is annoying!!!!!
  4. richard plumb
    richard plumb
    Jan 27, 2002
    14,477
    Windsor
    +1,046
    not considered the 30" Sharp or philips? Both are about £2k from most places.
    Or get that lovely JVC 26" you've had your eye on?
  5. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    If I go for one I reckon it will either be the 30" Philips (My neighbours turned up at 4pm this afternoon and they want me to install/set it up so will get the chance of an extended demo :) ) or wait for the new 32" JVC.
    Saying all that Comet had an offer on the LG 42" plasma today. £2099. Need to check the mags/reviews and see what they think/thought of it.
    Decisions. I may just decide to wait 6 months as it's only for the bedroom.
  6. MKPatrick
    MKPatrick
    Dec 11, 2003
    344
    Buckinghamshire
    +11
    I noticed the same - although I have to physically get behind the TV to hear the buzz. I tend toi use the 'normal' setting anyway as this seems to give the best contrat results.
    Still happy with the tv, though image lag with the internal tuner is very apparent, RGB and prog inputs don't seem to suffer from it.
    Patrick
