Thomson 24WT25US "borders!!"
Discussion in 'General TV Discussions Forum' started by JohnJm, Mar 22, 2001.
  1. JohnJm
    JohnJm
    Can anyone help me please?? It's probably a reallllllllllly stupid question but I recently bought a Thomson 24WT25US and successfully used the hack to watch region 1 DVDs. Brilliant. But when I watch them there is what I can best describe (I'm sure there is some technical term for them) two black borders top and bottom of the screen. This doesnt happen on region 2 discs so I was wondering if anyone knows how to get rid of them or if I'm stuck with them???
    Jason
  2. Des Horrigan
    Des Horrigan
    Can you tell me where you got the hack from as I am considering buying the 28" version.
  3. kdodd
    kdodd
    would you have a copy of the manual for the 24wt25 as i have the 24wt25ug but no manual and am struggling slightly on afew things
    thanks
  4. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    Do you have a bright white or multiple colored lines in between the upper black bar and the image? If so, your TV is not happy with the 60Hz input (this is probably common). Many manufacturers consider this type of anomaly to be within acceptable range.
    It might also be normal, as the movie image doesn't cover the whole active video area but has small black bars above and below (because of the 1.85:1 image fit inside the 1.78:1 picture area).
  5. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    Would this be the same kdodd from MS? :)
  6. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Assuming that you aren't watching a 2.35:1 film, the reason your TV is showing black borders might be because is hasn't been configured to display NTSC images properly. NTSC images are 525 lines top to bottom, PAL 625 lines, so the TV isn't stretching the picture to fit. A similar effect can be seen on some VCRs with NTSC playback functions. At a guess, I'd say that the DVD player is converting the NTSC image on the fly producing the effect. To test if it's the TV or the DVD player, hook up another DVD player to an RGB SCART and see if the TV does the same thing with R1 DVDs. If not then you can "solve" your problem by buying another DVD player.... not an ideal solution I know!
