thompson remote hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by ADEOWEN, Nov 21, 2001.
  1. ADEOWEN
    ADEOWEN
    Can anyone please tell me the hack for the thompson tv and dvd combi,its the model 24wt25us.thanks in advance
  2. Sick Note
    Sick Note
    Nov 8, 2000
    451
    +26
    don´t know if you´ve tried the standard thomson hack but here it is:-
    1)switch machine on
    2)press repeat on the remote
    3)punch in 38767 on remote
    4)there should now be a 02 in top left corner of the tv screen
    5)now press 9 on remote,the 02 on screen should have changed to 09.
    6)press open
    7)press stanby
    switch back on and it should be a code free player
    let me know if it works
  3. Sick Note
    Sick Note
    Nov 8, 2000
    451
    +26
    Ignore the above it´s ********!
    A mate of mine has the same tv doesn´t work but this does
    1)open tray put any disc in
    2)on front panel press and hold EJECT,FORWARD,SEARCH and OK
    this is a bit tricky and may take a couple of attempts but stick with it
    3)wait till tray closes
    4)release all the buttons:)
  4. ADEOWEN
    ADEOWEN
    Yep sicknote your one works,thanks a lot matey.....:clown:
